Sony DSC-HX20V (& HX30V) wont connect to my pc
Westcottage_1
Nuovo
Hi I have tried everything but I am unable to connect my camera to any pc or mac
New Sony cable I have several pc.s and it won't connect - I have tried play memory home etc it just won't connect
Help
1 RISPOSTA 1
Joe_Dohn
Specialist
macOS is no longer supported by PlayMemories on the latest versions, so your best bet would be your Windows PC.
That said, what happens exactly when you connect them? Do you get an error message, a connection chime, nothing at all, etc?
- JD
