Hello, I have a Sony ZV 1F that I am trying to use for streaming with an Avermedia Live Streamer Cap 4K capture card plugged into a PC and looking for some advice here.For some reason the info display is not showing up a lot of information like file format, framerate etc. as you can see on the screen. All this info shows up in slow motion though. What could be causing this?
If I change the file format for video shooting in photo mode does it also change the settings in the video mode settings too? Like what I'm trying to ask is, does it matter where do I change the file format or its one global setting?
I read that face detection AF is only partially working when the camera is in 4K and a micro HDMI is connected, what does this exactly mean? How much would this affect the AF performance, what can I expect?
Thanks for the help!
Camera screen info problem
