Is possible to buy wireless remote comander for this camera.Thank
Hi jerrymyn, welcome to the Sony Forums
Unfortunately CX130e has no wireless capability, as there's no built-in infrared receiver. I presume you're already aware of the corded controller available.
You can operate it via your TV's remote if you have a Bravia Sync-compatible TV and connect the two devices with an HDMI cable. Let me know if you need more info on this.
Cheers
Mick
Cheers
Mick
Thak you for your answer
Jerrymyn
HI Mick,
i notice that you mention a wired remote controller available for this handycam, I wondered if you would mind giving me the name of it please? I am desperately trying to find a remote controllable video camera that doesn't cost the earth you see. It's for personal use I'm no professional and I did see somewhere that the Sony model mentioned in this thread does have a lanc hence why I was looking at purchasing this handycam and getting a remote control.
I hope you can help.
Thanks loads
julie
Hi Julie, welcome to the Sony Forums
The corded remote controller is the RM-AV2, works with the A/V-R port on the CX130e and is listed on the sony.co.uk site here:
http://www.sony.co.uk/product/cac-other-accessories/rm-av2
You can also find one in the usual places online, camera shops etc.
If you do need to synchronise a cam with A/V-R but no LANC port, you can get a Sony A/VR-to-LANC converter that works quite well; let me know if you need to source one.
Due to the Sony A/V-R port being very common on Handycams etc, the AV2 is near-universal in terms of Sony cam compatibility, working with a huge range of new and old models:
http://www.sony.co.uk/product/cac-other-accessories/rm-av2#pageType=Compatibles
Cheers
Mick
