Help with Sony camcorder fdr ax53
SOLVED
Condle4l
New
Hello Sony Community.
Just purchased. All going well but now have a white camera with a white circle top right hand corner, in the middle of the screen when I press record. Not enough info on ghe manual for me to solve. Can anyone help?
Thank you.
1 ACCEPTED SOLUTION
darkframe
Hi @Condle4l,
I guess that the symbol about which you are talking is the one at the bottom of this help page (Warning indicator pertaining to photo recording). There are several situations (as mentioned in the help text) in which you cannot take photos. That's indicated by the sign.
Cheers
darkframe
Wo kämen wir hin, wenn jeder sagte, wo kämen wir hin und keiner ginge, um zu sehen, wohin wir kämen, wenn wir gingen... (© by Kurt Marti)
10 REPLIES 10
Joe_Dohn
Specialist
Not sure if this is what you're looking for, but here's a list of all screen indicators.
Condle4l
New
Hello! It's this white camera indicator.  Not sure what to do. Help needed. Stel. 😊
Sent from the all-new AOL app for Android
Joe_Dohn
Specialist
Can you tell me the name from the list I sent before?
Condle4l
New
Hello,
It is centre of screen  -  a camera with a circle to the top right. WARNING.
I really do appreciate any help you can give me.
Estelle
Tell me and I'll forget  Show me and I'll remember INVOLVE ME AND I'LL UNDERSTAND
IamNic
Hello @Condle4l,
can you take a photo of your cameras screen WITH the symbol with a photo camera or your smartphone and include it here?
- Nic
darkframe
Hi @Condle4l,
Cheers
darkframe
Anonymous
Not applicable
Hi Condle41,
A photo of the error message will be the most helpful way to solve the issue.
Condle4l
New
All sorted!
Thank you. Xx
Joe_Dohn
Specialist
Glad to hear the issue was sorted my friend!
