Hi all,
I'm trying to watch back footage directly from my handycam on my Sony Bravia TV.
Is there a way of watching back footage without having to finalise the disc i.e watching footage from the disc while it is still in the handycam?
I have connected the handcam to the TV using the A/V connecting cable but it doesn't seem to register that it is connected to the TV?
Thanks very much
Hello gman5467 - welcome to the Sony Forums
If you have connected the camera to your TV, are you saying that the TV itself isn't recognising the camera as a valid input after using the remote to choose the appropriate AV channel (depending upon which socket the AV lead is plugged into)? Have you scrolled through the various options available?
On the other hand, are you saying that you think the issue may be within the camera itself?
Thanks,
Simon
