DSC-F707 adaptador memory stick
RESUELTAS
profile.country.pt_PT.title
luispmorais
Visitante
Gostava de saber se máquina DSC-F707 pode usar o adaptador memory stick?
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
V57...
Colaborador
Caro luispmorais,
Bem-vindo ao forum da Sony...
Esse modelo é compatível/ou não  com qualquer os seguintes Memory Stick...
Os dados que não necessitam da função de protecção de direitos de autor (MagicGate) podem ser gravados/reproduzidos.
X :
Não compatível.
TipoModeloCapacidade/ClasseCompatibilidade
Sony
Memory Stick (com MagicGate)
MSH-3232MB
MSH-6464MB
MSH-128128MB
MSH-128S2256MB• (*1)
Sony
Memory Stick Duo (com MagicGate)
MSH-M32N32MB• (*4) (*10) (*11)
MSH-M64N64MB• (*4) (*10) (*11)
MSH-M128N128MB• (*1) (*4) (*10) (*11)
Sony
Memory Stick PRO
MSX-256S/X256MBX
MSX-512S/X512MBX
MSX-1GS/X1GBX
MSX-2GS/X2GBX
Sony
Memory Stick PRO Duo
MSX-M256S/X256MBX (*11)
MSX-M512S/X512MBX (*11)
MSX-M1GS/X1GBX
MSX-M1GST/X1GBX
MSX-M2GS/X2GBX
MSX-M4GS/X4GBX
MSX-M8GS/X8GBX (*9)
Sony
Memory Stick PRO Duo (Mark2)
MS-MT1G1GBX (*2)
MS-MT2G2GBX (*2)
MS-MT4G4GBX (*2)
MS-MT8G8GBX (*2) (*9)
MS-MT16G16GBX (*2) (*9)
MS-MT32G32GBX (*2) (*9)
Sony
Memory Stick PRO (alta velocidade)
MSX-256N256MBX (*2)
MSX-512N512MBX (*2)
MSX-1GN1GBX (*2)
MSX-2GN2GBX (*2)
Sony
Memory Stick PRO Duo (alta velocidade)
MSX-M256N256MBX (*2) (*11)
MSX-M512N512MBX (*2) (*11)
MSX-M1GN/X1GBX (*2)
MSX-M2GN/X2GBX (*2)
Sony
Memory Stick PRO-HG Duo
MS-EX1G1GBX (*2)
MS-EX2G2GBX (*2)
MS-EX4G4GBX (*2)
Sony
Memory Stick PRO-HG Duo HX
MS-HX4G4GBX (*2)
MS-HX8G8GBX (*2)
MS-HX16G16GBX (*2)
MS-HX32G32GBX (*2)
MS-HX8A8GBX (*2)
MS-HX16A16GBX (*2)
MS-HX32A32GBX (*2)
Sony
Memory Stick com TransferJet
MS-JX8G8GBX (*2) (*12)
Sony
Memory Stick Duo PSP
PSP-M3232MB• (*4) (*7) (*10) (*11)
Sony
Memory Stick PRO Duo PSP
PSP-MP1G1GBX (*7)
Sony
Memory Stick Micro (M2)
MS-A256A256MBX (*11)
MS-A512A512MBX (*11)
MS-A1GA1GBX (*11)
MS-A2GW2GBX (*11)
MS-A2GN2GBX (*11)
MS-A2GU2GBX (*11)
MS-A4GN4GBX (*11)
MS-A4GU4GBX (*11)
MS-A8GN8GBX (*11)
MS-A8GU28GBX (*11)
MS-A16GU216GBX (*11)
Legenda
X :
Não compatível.
(*1)
Os dados superiores a 123MB não podem ser gravados de uma vez só.
(*2)
A velocidade de transmissão pode não ser mais rápida se utilizar o Memory Stick PRO (alta velocidade/Mark2) e o Memory Stick PRO-HG.
(*4)
Deve ser instalado um adaptador (MSAC-M2) dedicado para poder utilizar o suporte Memory Stick Duo™ ou MagicGate Memory Stick Duo.
(*7)
Este produto é fabricado pela Sony Computer Entertainment Inc.
(*9)
O sistema de ficheiros incorporado no Memory Stick limita a capacidade de gravação ou reprodução de um ficheiro para menos de 4 GB.
(*10)
Este suporte não é compatível com o modo VX Fine para filmes em MPEG.
(*11)
Este suporte não é compatível com o modo de filme HD.
(*12)
Este suporte não foi comercializado em todos os países ou regiões devido a variações nos regulamentos das ondas de rádio.
Cumprimentos
Ver la solución en mensaje original publicado
2 RESPUESTAS 2
profile.country.en_GB.title
-charlie-
Visitante
Ola luispmorais! Seja bem vindo ao forum Sony!
Qual seria o memory stick que voce menciona? É o proprio "memory stick" (aquele maior, antigo) ou tem um nome e modelo?
Cumprimentos.
V57...
Colaborador
Caro luispmorais,
X :
Não compatível.
Sony
MSH-3232MB
MSH-6464MB
MSH-128128MB
Sony
Sony
Memory Stick PRO
MSX-256S/X256MBX
MSX-512S/X512MBX
MSX-1GS/X1GBX
MSX-2GS/X2GBX
Sony
MSX-M1GS/X1GBX
MSX-M1GST/X1GBX
MSX-M2GS/X2GBX
MSX-M4GS/X4GBX
MSX-M8GS/X8GBX (*9)
Sony
MS-MT1G1GBX (*2)
MS-MT2G2GBX (*2)
MS-MT4G4GBX (*2)
Sony
MSX-256N256MBX (*2)
MSX-512N512MBX (*2)
MSX-1GN1GBX (*2)
MSX-2GN2GBX (*2)
Sony
MSX-M1GN/X1GBX (*2)
MSX-M2GN/X2GBX (*2)
Sony
MS-EX1G1GBX (*2)
MS-EX2G2GBX (*2)
MS-EX4G4GBX (*2)
Sony
MS-HX4G4GBX (*2)
MS-HX8G8GBX (*2)
MS-HX16G16GBX (*2)
MS-HX32G32GBX (*2)
MS-HX8A8GBX (*2)
MS-HX16A16GBX (*2)
MS-HX32A32GBX (*2)
Sony
Sony
Sony
PSP-MP1G1GBX (*7)
Sony
MS-A1GA1GBX (*11)
MS-A2GW2GBX (*11)
MS-A2GN2GBX (*11)
MS-A2GU2GBX (*11)
MS-A4GN4GBX (*11)
MS-A4GU4GBX (*11)
MS-A8GN8GBX (*11)
MS-A8GU28GBX (*11)
Legenda
X :
Não compatível.
(*1)
(*2)
(*4)
(*7)
(*9)
(*10)
(*11)
(*12)
Cumprimentos
