Every time I changed to front camera. The front camera failed to work and camera stop working
Hi @Alonelonelysaga, sorry to hear about this.
Have you been able to carry out a quick test of the front camera in the support app to see if the hardware works as intended? Find and tap Settings > Support > Xperia tests > Front camera. Also, try clearing the data for the camera app. This will not erase any previously taken photos, but it will reset all settings for the app which might do the trick. Find and tap Settings > Apps > Camera > Storage > Clear data > Tap "OK" > Restart the phone.
Another thing that you can try is rebooting your phone in safe mode to see if you are able to switch to the front camera there. All apps downloaded from Play Store is temporarily deactivated while in safe mode and by doing this, you can see if this behaviour is caused by a downloaded app. For more information on safe mode and how to use it, click here.
If the camera behaves the same way in safe mode, I would suggest that you try to repair the software using a computer and Xperia Companion. Keep in mind though that a software repair will erase all user data from the phone, so make sure to do a backup of your user data before the repair.
Try these measures and let me know how it goes!
