Hello,
I have read multiple reports / concerns with Audio lag between the HT-CT290 sound bar and HDMI ARC to TV's.
I just recently purchased the above TV and Soundbar and the lag is very very noticable.
Almost unbearable... I cannot find a solutiion - is this really an overall issue with Sony or are there settings i can tweak to fix this major issue?
Thanks in advance...
I have this problem before with X8000D & CT-790. The hdmi cable that include in the box not suit enough for ARC bandwidth so I replace it to "Monster Black Platinum Ultra HD High Speed Cable 050644743627" it capable bandwidth up to 27Gbps.
After replace it, problem fixed.
