Xbox one x picture settings
Tfizzler
New
If anyone has set one up.  The settings you used would be greatly apprciated. Like the gamma, black levels etc.
I have a 49xd7005
Thanks
1 REPLY 1
jumpsuit
Hi @Tfizzler and welcome to the Community :slight_smile:
I don't own a console so can't advise personally, but there are some videos on YouTube
that may help.
One example is Here
which shows you how to enable HDR gaming on the Xbox One S & X.
Another example is Here
which although for a different model Bravia, and a PS4 Pro,  should give you
a starting idea for gaming settings.
Hope this helps
