- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
December 2016
December 2016
VESA Mounts - Sony KD-49XD8305
Hello
Can you tell me how a tilt and swivel mount would work?
I cannot specifically find a 200x300mm mount. What size mount do I need?
Has the headphone bluetooth problem been sorted out yet?
Thanks all!!
1 REPLY 1
Anonymous
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
December 2016
December 2016
Hi there
Tilt and Swivel - TV can tilt up and down, and then swivel left/right.
A quick search on Amazon brings up:
https://www.amazon.co.uk/Masione-Articulating-TV-Mount-Bracket/dp/B019VXAKPG/
They are around, just look.
Sony recommends its own bracket - which tilts upto 20 degrees:
https://www.sony.co.uk/support/en/product/SU-WL450
Cheers
Full Motion Articulating Arm TV Wall Mount Bracket for 22-60" TV LED LCD Plasma Flat Panel Screen Specification: 1. Distance to the wall:2.8"-22.5" 2. Durable Black finish. 3. Supportable Display Size: fits 99+% of TVs for 22-60" 4. Load Capacity: 66 lbs (30KG). 5. Material: 2.0mm SPCC (Cold Plat...
