Soundbars
Hi I have a KDL-43wd75x and would like to add a soundbar, does anyone know how to go about thisplease I cant find any info in the book. Thank you
2 REPLIES 2
Anonymous
Not applicable
Hi there,
Here is the guide to connect a soundbar to your unit: https://bit.ly/2Ktb0CG
Let us know how you get on, and welcome to the community. :slight_smile:
Best wishes,
M
royabrown
Enthusiast
Hi - it's on page 30 in your manual.
Either HDMI or Optical, depending on the capabilities of the sound bar you choose.
If it has HDMI, then if you connect it to the HDMI input on the TV marked ARC, it will operate almost automatically, in the matters of switching on and setting the volume.
But if not, connect it with an Optical cable.
With that you might want to look at the settings for audio on the TV, and ensure the Optical output is set to give variable level, not fixed, so you can still control it with the TV volume control.
YouView Superuser, but not an employee of YouView, nor retained by them for this purpose. It's purely me speaking
