Hi all have just purchased a don't bravia 43xe8077 the sound is very good but could do with it being a bit more of base have used equalizer is there any other way ty
Hi Spangles
That sounds like the best setting to change.
Often a soundbar is the best way of improving the sound from your TV. They're not hugely expensive as sound systems go, and the difference can be dramatic.
Have a look at these Sony products. Other brands will work too.
Cheers
Mick
