- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
SONY tv android and vpn app problem
I have the Sony TV KD 55xf9005 and I have installed the kaspersky vpn, but when I open it, it appears in a small part of the screen (see the photo), and I can't make any adjustments. Is there a way to fix this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
looks maybe like the app is designed for mobiles only and not actually tv so the resolution problem and aspect ratio is probably designed for a mobile screen, i may be wrong, but ive seen android mobile apps only open up like this on the tv, you could try altering the tvs aspect ratio, if you have that set on auto try it on zoomed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I searched but couldn't find an aspect ratio setting on the TV, so I can't try it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@teligal I think it will not be adjusted, you can try deleting and redownloading it, if the same issue happens so it's clearly the App is not designed for a TV.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
i did that too, but unfortunately nothing happened. It's a shame because I bought this application in order to install it on TV and a tv box. It was successfully installed there, but not on TV.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @teligal, what is your TV model name? You can use this link to help you locate the model name: https://www.sony.co.uk/electronics/support/articles/00248604
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
i told you in the first post....KD 55xf9005
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@teligal Well, the best option is to contact Kaspersky's software creators to address that issue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have already done it, they told me that it does not work with tv and android box.
I installed it on an android box and it works without any problems.
On television, however, it appears as shown in the picture.
Finally they told me to ask on the sony forum, if there is a solution!
