Sony kdl43w805c Android TV cannot start
SOLVED
Dongy_
Hi all,
My Sony Android TV (kdl43w805c) has suddenly stop starting. I can see the logo sony appearing on the TV and white led starting blinking smoothly but then the TV stops and start again forever. I have seen previous mentions of this problem on the forum but it does not seem that anyone has found a solution.
So far I have tried the soft and hard reset. I even tried to force the hard reset using the buttons located on the back of the TV. It did not do anything as the TV keeps starting and stopping all over again.
Has anyone found a solution to this problem?
Many thanks for your help!
21 REPLIES 21
Pneill
Yes, definitely contact them on customersupport.en@eu.sony.com
I had given up until the service center suggested the TV should be covered
by the warranty.
Hopefully you are covered. Let me know how you get on
Rcecil88
Thanks for the advice I will let you know if I have any luck! It’s driving me mad I have no working tv all thanks to a software update causing my tv to crash
