sony KD-65XD7505 4k settings+calibration settings for xbox one x
profile.country.EE.title
aqarwaen29
Ontdekker
does anybody what best picture settings for xbox 360 and xbox one???even with my best effeorts picture  is blurry...
can anybody post me best settings for best 4k picture???
here are my picture settings..
https://imgur.com/a/gnwGTOo
3 ANTWOORDEN 3
romeo_kii
Lid
hiya , get onto game mode first loll, your pictures show your on cinema pro, then change colour from expert 1 to warm , neutral or cool, ( i mainly use cool )  ,brightness 25 depending on room light , contrast 100, colour 70  ,hue 0 ,   sharpness to 65,gamma 0 , black level 50 ,  black adjust med or high , stay away from advance contrast enhancer or live color (if you like live color try n keep low loll)  , take off all motion enhancers ie reality creation, noise reduction, motionflow, film mode  stuff , thats all really  , these settings look best on my sony tv , all the best
aqarwaen29
Ontdekker
so i switched to gaming,but now it says 4k in remaster is off..so does it mean all games will run at 1080p then using game mode,since its turned off at settings..
that main reason why i use cinema pro mode cuse there i can get 4k enabled
romeo_kii
Lid
hiya , that 4k remaster is not for games , mainly for bluray movies , your tv will upscale/downscale  the image if content is found , if your playing on normal xbox , your tv will display 1080p max( but tv will still upscale) for image to be full  but if you have a ps4pro or xboxone s/x it will be in 4k 2160p, i have xbox one s and ps4 pro , both display in 4k 2160p , you need to be in game mode  for good input lag whilst gaming , evrything will feel good ie moving , shooting , jumping , but if in cinema pro , games will be fuzzy and feel slow , not a good  clean image loll
