Is it possible to make it go to view the program after just one press of the ok button.
I really couldn't care less about the extra details I can see about a program - for example do I need to know or care who the cast and crew of storage hunters are???
At the moment you have to select the program with one button press then press view with a second button press. Why doesn't it work like a normal epg where you press an information button for information about the program and a view button to go straight ahead and view it.
