sony bravia amazon prime fail
thomashowie
New
Amazon prime app taking so long to load, then crashes with error message stating insufficient bandwidth, which is utter nonsense. Netflix shows download speed of 45gbs and performs seemlessly in all respects.
Would appreciate any input regarding this annoying gltch as previously it worked OK.
3 REPLIES 3
thomashowie
New
Prime app takes forever to load then crashes with error text stating insufficient bandwidth. That is total nonsense my Netflix app shows 45gbs and runs seemlessly with no issues whatsoever.
I would appreciate any help with the problem.
Thanks in advance.
Thomas.
IamNic
Hello @thomashowie,
have you tried resetting the apps cache or reset it to default settings?
- Nic
Anonymous
Not applicable
Hi there,
Have you updated to the latest firmware?
Best wishes,
M
