Please help me with the base stands
SickboyCZ
Nuevo miembro
Hello all,
I have Android 4K TV model KD-49XD7005 (I know it's not a total zinger).
What I want to politely ask you is...
The tv has shaft table top base stand like this one (see the picture below)
Now I want to buy a soundbar (Sony HT-X8500) and put it in front of the tv. But the current default base stand is too sticked out and interupts placing the soundbar. So I really want to replace it with different base stand with two separate wider spreading legs (like these ones of model KD-49XF7005 - see the picutre below)
Do you know if it would fit? Do you know where I can get/order the part? Any other advise or recommendation?
Thank you guys for any answer.
All the best from the Czech Republic.
1 RESPUESTA 1
rooobb
you cannot swap the standard stand of the tv, but you can find anywhere a new stand that has VESA compatible connection with your tv
