Ongoing issues of unsuccessful firmware Updates, must persuade Sony(or Google) Programmers, to include during flashing startup procedure of New Firmware, the option to Perform a "Factory Reset" Update or a "Keep previous Settings" Update.
This means that @aoriol and all others with similar issues, during next firmware update, that will be performed only by a USB flash Firmware, shall have the option at the begging to perform a Clean Update to remove any accounts or apps that might cause issues.
1. Perform a clean installation Update (Everything shall be erased)
2. Perform Update Only (Your apps and settings are not deleted)
I hope I am not wrong again and these option are already included
Hi @Anonymous
It's OK now I think. I mean with the Force Factory Reset procedure.
Many wishes to all people and a Happy New Year for all of us.:smileyhappy: . And peace of course
all over the world.
You know, I did read this at the time. But I just cannot see Sony/Google developers including this option. Factory resetting is advised if anyone experiences problems afterwards - but its up to the individual TV owner to do this.
Also having extra options prevents automattically updating/installing over night etc (i think)
I always think it should be Happy Christmas and a Merry New Year - we seem to drink more on New Years eve, hence the Merryness !!
