New Firmware April 12
profile.country.GR.title
MiCal1967
Contributor
Today I can see a new firmware is available through TV settings.
But, I do not see this available for download and install from usb.
KD-55X8508C
61 REPLIES 61
Jono808
New
I'm confused, Sony seem to be saying that the issue is solved but I am still getting ui-800-3 when opening Netflix.
Model Bravia 4K 2015 KD-43X8309C
UK
BT Home Hub 5
Tye1991
Have you tried
- Logging into MYBT and disabling (if needed) BTProtect and BTParental controls
- RESETTING as opposed to restarting the hub. The reset option is located at the back and involves pressing a pin against it.
I had the same issue with a BTHUB5 and resetting it fixed the problem for me :slight_smile:
