Led At the bottomof TV stays on
muffin1947
I have a Sony Bravia TV Model Number KDL-42W653A and when I normall turn it on a white light at the bottom of the normally flashes on then goes of but now when I turn the set on I get a orange coloured light which stays there even when the TV is turned off can someone on explain what the problem is
Thanks Paul
4 REPLIES 4
rooobb
On these TVs an orange light normally means that a timer is set...
muffin1947
So how do I turn the timer off and how could I have turned it on.
Thanks for your swift reply
rooobb
It can be one of the different type of timer supported by your TV (i.e. if you have set it up an HDD for programme recording). If you cannot find it and it bothers you you may switch it off in any case https://helpguide.sony.net/gbmig/C5181001/v1/eng/c_gset_europeall_co_illumi.html
MaggieGreene
@muffin1947 This link explains how to turn the sleep timer off: https://helpguide.sony.net/gbmig/C5181001/v1/eng/c_clock_sleep.html
