I need a remote for my bravia will I also need codes to reset my tv as well?
Hi @HaZeL67.
Remote: Your best bet is to search Amazon or eBay for "KDL-40EX400 Remote".
Exactly what codes are you referring to? Please note that your TV is not supported in the UK, so are you confident it will even work on our broadcasting standards. It is a 2010 model, so 15 years old.
