Input menu
SOLVED
Fanno112
Input menu
Hi is there a way to change the order of  theses inputs or delete some ?? Plz thanks
1 ACCEPTED SOLUTION
rooobb
If you go to the last row, you should found the setting option and there you can for sure set which rows to show and (but I don't remember) you should be able also to change the view order.
2 REPLIES 2
rooobb
Fanno112
That’s it , many thanks
