jobbybhoy
Infrared blocked
my sound bar blocks the ir sensor on my Bravia kdl 50w805c, is there a ir repeater or some way to fix this.
3 REPLIES 3
Anonymous
Not applicable
Hi there
There are many ir repeaters - search Amazon and read up to see which one best matches your requirements.
Cheers
jobbybhoy
Thanks but what type suits Sony
Anonymous
Not applicable
Hi there
Ive not used one, so i cant recommend, so your best to do a little homework yourself.  Ive had a scan of Amazon, an d this seems good for £11
http://www.amazon.co.uk/Repeater-Infrared-Control-Extender-Receiver/dp/B00S4IB6PS/
One of the questions for this product is:
http://www.amazon.co.uk/forum/-/Tx2R4UXV7E4HA0Y/ref=ask_dp_dpmw_al_hza?asin=B00S4IB6PS
There are no 'recommended' ones. So, if you find one and it does the job, please post back as im sure it might help others.
Cheers
