HALauncher stops working after reboot
mameha1977
I installed HALauncher to quickly access the sideloaded apps that do not support leanback launcher.
After initial install, it worked great.
After rebooting the TV, it no longer works.  If I click the HALauncher icon it starts to open then falls back to menu screen.  Sideload Launcher works OK but it is slow and my favourite app starts with X so appears right at the bottom of the list!
Does anyone else have this problem or can suggest alternative sideload launcher?
Tags (2)
1 REPLY 1
Anonymous
Not applicable
Hi there
If HALauncher is still not working, try removing it and re-installing.  Alternatively, try TV Sideload Launcher
https://play.google.com/store/apps/details?id=eu.chainfire.tv.sideloadlauncher
Cheers
