When I've tuned my tv to freesat on my X85c Android tv the guide doesn't populate with shows unless I tune to channels individually, and the channel numbers don't match up with the sideview app.
Is there a way to match up the channels or to get the guide to populate with information?
I get the same problem with this. I have to wait up to 5 mins to get some sort of guide come up, but i get nothing at times..! I had the set plug in to my sat dish, and after all the issues i have had, i have now got an old sky+ box, and running the set that way via HDMI-1 input. I loose all data with the signal lost, but at least i dont get the lip sync issues any more, no waiting for the guide no more....but lets face it, did we buy these TV's to do all this messing about.....
Sony are calling me tomorrow ( FRI ) and i have decided to return the set back to them now.
But dont forget to ask for the £100 refund they are giving customers of these sets, due to the issues we are all having....then return it..!
Take care.....
Hi, can you provide any more info regarding the £100 refund please? How can you go about claiming for it and is it available to everybody that have bought this TV and not necessarily bought from Sony Online or Store? Cheers for your help
