Comparte tu experiencia!
i have just found out that apple tv4k has done a softwarte update os.11.3 so thate the box can work with sony tv to stream dolby vision over h d m i but so far it is only in the u s a they are waiting for sony to update in the uk
So the yanks get another update https://esupport.sony.com/US/p/swu-download.pl?mdl=XBR75Z9D&upd_id=11447&os_group_id=18
Mean while we get JACK ****
What's the betting the update will come out when the X700 player does?
Mods on here won't answer, so what's the point of this forum?
sorry but i forgot sony have said the dolby vision update for the x-700 will be coming in the summer but i wont hold my breath as it has been over a year i have been waiting for the update on the zd9 and it has still not happend
@Sean_Mcwrote:Hi Stewart,
You can find the latest firmware update here.
Cheers,
Sean Mc
"Dolby Vision content is supported for video streaming apps/services installed on the TV such as Amazon Prime Video and Netflix. (ZD9, XE94, XE93 and A1 only)*"
We was promised DV over HDMI...I'm not installing this.
EDIT=
"Selected Sony TVs (ZD9, XE94, XE93 and A1 Series) will support Dolby Vision with the software update to be rolled out in Europe within April, 2018"
