Делитесь своим опытом!
Hi,
I've had the above TV since November 2015 and on 3 seperate occaisions it does the following:
This means that you can't do anything - you can't get into the settings etc. Unplugging it for 30 mins or so does nothing. If you leave it unplugged all night in the morning it works like nothing was ever wrong with it!
Any thoughts?
Решено! Перейти к решению.
Hi there
Unfortunately your problems are issues that have already been reported. See:
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/td-p/2040020
Especially items 24 and 42 on the list.
Cheers
Hi there
Cheers
Thankyou, it isn't unfortunate as at least Sony are aware. I was thinking that I may need to send my TV for a repair!
