Bravia 8 stuttering since Firmware 114.602.030.1 update
baz8755
I have been using my Bravia 8 65" for over a year on the same settings and it has been perfect. However a couple of weeks ago it updated to the firmware with the new EPG without channel logos.
Since then the image on quite often starts to stutter. This can be seen on OTA transmissions through the antenna and on inputs.
When using the antenna it will often begin to get jerky/stutter and I can change channel and change back again and it will be fine for a while but sometimes comes back again.
I have checked all my image settings and they have not changed.
It would appear this new version of firmware has broken things and many people on AVS forum, Reddit & Facebook are reporting similar issues.
Tags (2)
31 REPLIES 31
LightFoot
Specialist
Hi @baz8755   Have you reported this to Sony? Sony Support.
baz8755
I reported it using the send email option
Lewbuttoni
I also have the same problem since the update, mainly notice the stuttering on ITV 1 HD channel, changing channel and the back again seems to cure it temporarily, but it returns.
I will report to sony
baz8755
Having done a bit more investigation I am pretty sure it is the TV app that is broken.
SONY have obviously updated the app to remove TV logos and the font and wording on the PVR is slightly different.
However I rely on the TV app rather than alternatives as I use the PVR functionality.
Disapointedbravia8
New
We have also had this since the update, been jumping though the hoops with Sony trying to get sorted, they have now washed their hands and directed us to an authorised repair centre to repair and we have got to pay! Tv is 18 months old and basically their attitude stinks, will never buy Sony again, luckily still got the trusty old Samsung to watch!
Lewbuttoni
I'm still having the same issue on a daily basis, despite numerous correspondence with Sony getting and nowhere.
The problem is on free to air HD channels BBC , ITV etc.
Only remedy is to switch channel and back again, but the issue reoccurs later.
Had my Ariel installation checked, replace cables etc.
chopsbtv
Same on Bravia 7 K-75XR70, framerate will.drop but will revert to normal on scene change after a few seconds.
doyled74
Another disgruntled user here. I came to a Sony 65" from an LG 55" which was excellent.
The stuttering has occurred since the recent software update and affects multiple HD channels. I'm relieved to hear that it's not an issue with the TV itself, so we'll now see how Sony responds.
Frankly the TV software has been a major disappointment. It's difficult to understand how it's so complex and utterly poor compared to LG's offering, and my next TV will definitely be an LG. I think I've counted 3 separate EPG's alone.
Not sure if I can log a support call or go back to my retailer John Lewis to have them escalate.
daveyh64
Enthusiast
According to owners of the Bravia 8 M2 on the AVForums Bravia 8 M2 users forum
Sony have said that a firmware update should be released around August 19th which
should take care of the problems introduced with the last update.
