Bravia 8 stuttering since Firmware 114.602.030.1 update
baz8755
New
I have been using my Bravia 8 65" for over a year on the same settings and it has been perfect. However a couple of weeks ago it updated to the firmware with the new EPG without channel logos.
Since then the image on quite often starts to stutter. This can be seen on OTA transmissions through the antenna and on inputs.
When using the antenna it will often begin to get jerky/stutter and I can change channel and change back again and it will be fine for a while but sometimes comes back again.
I have checked all my image settings and they have not changed.
It would appear this new version of firmware has broken things and many people on AVS forum, Reddit & Facebook are reporting similar issues.
Tags (2)
4 REPLIES 4
LightFoot
Specialist
Hi @baz8755   Have you reported this to Sony? Sony Support.
baz8755
New
I reported it using the send email option
Lewbuttoni
New
I also have the same problem since the update, mainly notice the stuttering on ITV 1 HD channel, changing channel and the back again seems to cure it temporarily, but it returns.
I will report to sony
baz8755
New
Having done a bit more investigation I am pretty sure it is the TV app that is broken.
SONY have obviously updated the app to remove TV logos and the font and wording on the PVR is slightly different.
However I rely on the TV app rather than alternatives as I use the PVR functionality.
