Bluetooth problem on Android tv 65XE8596
Lerch82
Good day
I have a Sony Android tv 65XE8596 fm last May and I need your help (if possible) abt bluetooth audio stuttering problem (on both modes.. TV or Streaming)
I tried  a lot of bluetooth devices, no problem to connect them, but they have audio interruptions on first 60 sec playback. Then the audio becomes good until I change the program/channel
At the moment I'm going to evaluate to connect an external android box or an external bluetooth 5.0 device via optical audio, bacause  also AV sync setting not help
Any comment or suggestion is welcome
Thanks a lot
4 REPLIES 4
Sean_Mc
Hi there,
Have you tried a reset on your TV. You can see more details on how to perform this here.
Let me know how you get on?
Best wishes,
Sean Mc
Lerch82
Hi, yes tried TV reset but the problem is still here 😞
Sean_Mc
Hi again,
Sorry to hear this has not resolved the issue.  I would recommend getting in touch with the support team for further help here.
Best wishes,
Sean Mc
Lerch82
Someone use bluetooth with earphones not sony without problem?
