Hi there,
I just bought the Sony Bravia 49 X8309 C.
I tried using Amazon instant video, the app loads and I can see programms and movies but an "Unknown error" shows whenever I try to play anything.
I have an amazon prime account (works fine on my laptop)
The internet connection is fine (everything else works fine)
I tried to link it in the sony account thing, but it says I do not have a device that supports it.
Is there a fix for this?
Thanks for any help
Hi there
In general terms, if the app loads but fails to play content this is generally an Amazon fault/issue.
A couple of suggestions that may help:
Cheers
