ads are freezing and won't go to the app
SOLVED
daro2096
Trying to play Just Another Solitare on my Sony Smart TV but the advert freezes at the end and it won't start the app.
Sort it out Sony.
1 ACCEPTED SOLUTION
daro2096
What ever treak was applied it seems to work now.
5 REPLIES 5
Actionman
Sounds same kind of problem with my new Kdl 48w585, it go fine to internet tv sites, allows to choose programs and displays local advert nothing else, i can replay ad, go back, choose another program, ewerything seems working fine but sites with this local ad on start does not work.
Actionman
Example Arrival, Beekeeperstories and Aquageeks channels has this issue, Youtube and Deutchewelle works fine.
daro2096
Advert was gone yesterday could play app. Today advert is back app won't start.
daro2096
Actionman
Same here, sony works perfect!
