adding speakers an option? Soundbar HT-NT5
sneish
Hi, Hoping to get some advice as not knowledgeable on these things.  I purchased a Sony tv and soundbar in 2018.  My mum is having issues with the sound as her hearing is deteriorating.  I wondered if it would be a good idea to add in rear speakers to our system and wondered if anyone can comment on whether a good thing and possible to do with our current setup.  I have a KD-49XE8005 with a HT-NT5 soundbar.  If you are wall mounting speakers is it best to have them at roof level and pointing down into the room or would you get a better effect if a bit further down the wall?
Thanks in advance for any advice :slight_smile:
Tags (1)
4 REPLIES 4
LightFoot
Specialist
Hi @sneish   I believe the speaker below has been designed to provide a personal speaker to help those that need extra local clear sound like your mum.
https://www.sony.co.uk/electronics/televisions-speakers-speaker-grilles/srs-lsr200
sneish
Thanks very much for that.
If anyone can advise on generally adding rear speakers to my system that would be appreciated too as I would like to have more of an all round sound experience.
royabrown2
Hero
@sneish
Rear speakers will not help your Mum, but the unit described by @LightFoot certainly should.
But if you want rear speakers anyway, they should be at about head height, for a person sitting.
Higher mounted speakers are for Dolby Atmos, which your sound bar does not provide.
sneish
thanks for advice on what level to fit speakers, now just to have a look and see what is available
