2015 Bravia Android TV Issues
NickCo1979
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
6,373 REPLIES 6,373
hextablephil
I have exactly the same volume fault on my Sony bravia  2015 tv (55" 3d ) .
Sony know about this fault, I still cannot understand these manufacturers that release updates that don't work,
I have contacted sony and tesco where I purchased the tv. Neither company are willing to refund as they say it's a software problem not a hardware malfunction.  Next step is trading standards.  Then Mr Martin Lewis of www.moneysaving expert.com.
Like you I've given them 2 weeks to fix
frogger38
@Anonymous Now that we can log in again...
Generally the system is stable since the April update.
I have ONE anoying issue out-standing which relates to the response of TV to the remote commands. Sometimes on click of a button it is interpreted as multiple clicks and at other times whilst navigating the menu or apps, sometimes the tv stops responding to remote clicks. if I then wait for 20 seconds or so it starts wrking again.
Product is is Sony 2015 KDL 43W805C Android TV, UK Model with YouView, purchased Sept 2015.
Kenneth_J
So i decided to keep my TV in hope things eventually will get fixed. Suddenly i'm having a new problem, when i turn off my TV the picture turns off but they sound stays on for 15-30 seconds..(maybe android is living it's own life inside my TV) o.0
If the annoying reloading of the TV guide and the youtube lag build-up isn't fixed by the time PlayStation VR is released i sure hell ain't getting them or the PS4k.
John1950Hitchin
I thought you had put the TV in the loft and not using it, maybe thats why it's gone quite in here. I do hope it will not wind you up though. :slight_smile:
REALLY HAPPY CUSTOMER.
hextablephil
Why would I put the tv in the loft....??? You don't know me..
Kenneth_J
I have never said i would put my TV on the loft, why would i do that when i could return it o.0
Wind me up??? i got a TV that doesn't work as it's supposed to, or even close to... should i just let it go and wait for next model?
john.pringle
I think John 1950 is referring to addyjays post😀
John1950Hitchin
Yes John that's correct.
John1950Hitchin
With 587 posts it's a little hard to remember who said what but I do remember that post.
adyjay33
Yes it will go in the loft but as a new TV costs money until I can afford a
new one I have to put up with this piece of junk...
Unless of course you want to give me the money? 🙂
KD-55X8509C LATEST FIRMWARE
NOT A HAPPY CUSTOMER!
