People with the 4K stutter issue, have you tried disabling motion flow and film mode, does this fix the issue? Had a similar issue with Apple TV a few years ago and this fixed it.
yep, its not a motion flow caused issue.
@Risc0n, just tested by turning off MotionFlow and Film Mode. Had no effect, still juddering 😞
I suspect it's likely caused by these TVs not being able to cope with the high data-rate of 3840x2160 50P on it's HDMI inputs 😞
I see on another thread this statement:
@Quinnicus wrote:
Sony are now concentating on the upcoming Marshmallow update. Outstanding issues will be addressed via Marshmallow now.
Does that mean ALL outstanding issues, including the 4K juddering problem affecting all 2015/16 TVs? And what is the release date for Marshmallow - before 13th August?
@chrgray - somehow I just knew that was going to bite me
I wrote that because it is largely true - however at the time, I was not aware of the BT UHD/Sky Q juddering issues.
What I should have wrote is:
Unless there is a major issue, outstanding problems and issues will likely be addressed within Marshmallow.
Im also not saying that all issues will be fixed immediately either.
ETA on Marshmallow = Unknown.
@UKPiglet wrote:
Unfortunately that won't happen as only one Sony employee is allowed to post in these forums, and he is a German speaker who doesn't often contribute to the English forum.
Yes, Sony haven't really grasped the idea of social media yet. So the steam we generate in this forum just vents through a safety valve, not even blowing a whistle. Whereas it could be driving a piston that would give Sony some momentum to get these damn TVs properly fixed 😞
Is Sky Q now broadcasting in 4K? What are you guys actually watching to see this judder? Has anyone got a UHD bluray player, does that exhibit the same judder?
@kevinwoods12 wrote:What are you guys actually watching to see this judder?
This - http://m.youtube.com/watch?v=5-myt8ZoVvY
Only seen when the Sky Q Silver box is set to output 2160p50, and only seen on Sony TVs.
Interesting, Sony Account Manager was updated for Android 6 ( Marshmallow ) support today.
