Well I guess now your problem has been solved there is no need for you to be here or are you now here to make sure no other person can speak even though you really dont have a reason to be here?
Maybe like your friend Gary you dont like others to have a say?
What about those that do have a problem, can they say they have or are we not allowed to speak about it?
Just wondered...
I see you did not answer any of my questions, so I guess you are in the dark as most of us are about how Sony are not solving the issues they have made with these TV's. To be honest some people have had these TV's so long that they will probably fail due to age than get sorted out.
After seeing posts about how bad they are in the past and still in the present is it any wonder I complain when I have a problem?
I came here in the vain hope that Sony would be here to talk to us about it, obviously I was sadly mistaken, I mean it is a Sony forum after all... what was I thinking?
I have never said you can't post so why should I stop. I have no Idea how to make your TV the way you believe it should be I am a TV viewer, no technical knowlege, just a happy owner. I will keep on posting, you and no one will stop me.
Then make a damn thread about how great your tv are *****... here we have issues... check out the thread title.... <profanity removed by moderator>
So why are posting to counter my negative posts as you stated in a previous post to me?
People with problems dont care your TV is fine, they want answers to their problems and everytime you counter what a person posts who has a problem you and others are just making their situation worse?
Cant you and others that do the same counter posting see this?
I rest my case...
Well now thats out of the way, who can solve others and my TV problems?
Sony where are you?
What's out of the way. I am still here. 🙂
Good luck with your problems.
Stating that I am here to get my problems solved, not to argue with people who just want to argue for the sake of it.
Stay as long as you like, but keep counter posting about your perfect TV, wont make the problems of others fade away.
Gald you got it sorted... 🙂
What model was you LG TV?
