Auto picture setting is broken. If I choose say PS4, it will set game mode. But when I switch back to Sky it will stay locked on game mode unless I disable auto picture....
Another bug in this new firmware. Every so often, all on its own, my TV displays a Google Cast screen, so I have to select HDMI4 to get back to watching TV.
How can I disable Google Cast, or better still, revert to a working firmware?
I just tried my first factory reset which has resulted in an unresponsive TV (55W755C) with a black screen... Do you normally get any status indication when performing the operation? -and how long does your TV take to do a reset?
Hard restart (power plug) has no effect. The reset was attempted after successfully updating to 3.179 (EU).
Best Regards
Simon
Another bug. Every so often, I keep getting a message displayed "Cannot Play Song". How do I fix this, it's very annoying.
Same problem as SimonM_DK. Updated no problems, watching BBC 1 for an hour or so and getting lip sync issues, so went for a factory reset. Sony logo appeared but no android start up logo, just black screen. Waited 15 mins and went for a hard reset - again giet sony logo but no android astart up logo and black screen. Any ideas??
mystiqu wrote:I think this version for UK is the equivalent version of 3.169, made for the rest of Europe.
http://www.sony.se/support/sv/content/cnt-dwnl/prd-tvhc/bravia-kd-4Kmodels-firmware-update-v3169-eub... (swedish - use chrome thanslate )
Version 3.169 fixed pretty much all issues for me
-A/V sync issues
-Remote lag-Black screen
-Freezes
-etc
Sure, the UI is not the most responsive in the world but in 10 days (since the update) I've not experienced any of the issues above. It now e.g. checks for a valid network connection before trying to do something that requires just that - probably something that caused some issues before.
I have only noticed some remote lag when being a bit too fast in the menus - something that resolves itself if leaving the remote "alone" for a few seconds.
Huge improvement I must say!
//Mike
Forgot to mention...
I got some weird behaviour after my update, and followed the routine below which fixed all my issues.
I never thought it would work since factory reset usually doesn't fix anything - just keeps you busy
@Davidrfarr, if you have hdmi and or usb plugged into the back, remove these then cycle the power off on at the wall then hold the power button on the remote for a couple of seconds, our 5th new tv done this last week and the above cured it.
I had the same issue and instantly regretted running the update, especially as I didn't have any issues beforehand.
I just had the black screen with the white LED indicator lit up. I ended up unplugging at the jack point into the TV 3 times before the TV rebooted.
@SimonM_DK wrote:I just tried my first factory reset which has resulted in an unresponsive TV (55W755C) with a black screen... Do you normally get any status indication when performing the operation? -and how long does your TV take to do a reset?
Best Regards
Simon
I had exactly the same problem and I ended up replacing the TV.
Even if you manage to fix it, the problem will return and get worse.
EDIT: Are you based in the UK and is your TV UK sourced?
