2015 Bravia Android TV Issues
NickCo1979
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
6,373 REPLIES 6,373
Anonymous
Not applicable
Hi all
Just to clarify, this update is for:
  • 2K (W Series) - UK and EU
  • 4K - UK Only.
Cheer
Tarzion
@NPatri wrote:
Thank you @Tarzion, but changing the link to .ie takes me to UK version...
http://www.sony.ie/support/en/product/KD-65X9005C
Tarzion
@Quinnicus wrote:
Hi all
  • 4K - UK Only.
Cheer
Thank you..
I am pretty sure I saw the same update on the IE site..
profile.country.GR.title
NPatri
Thanks but this takes me to the old version... My tv is a 4K, so no treat for me...
Anonymous
Not applicable
@Tarzion _ Your Welcome.  I should have posted that info originally :slight_smile:
waynefatboy
Anyone know why u can't assign the TV button to goto an hdmi port with the UK firmware but u can with eu firmware?
Risc0n
Contributor
@Quinnicus wrote:
Hi all
  • 4K - UK Only.
Cheer
Super, is this over the air as I am at work?
Also so does this fix the full screen 3D pop up and will I be able to upgrade to the UK version from EU 3169?
frankie1g
He says 4k as well but does that meet not x 4k tvs
Sent from my Samsung device
Risc0n
Contributor
You need to disable Youview.
Anonymous
Not applicable
It will also be released via OTA as well today.
