I'm on the latest firmware. Prior to that I had experienced relatively few problems at all. Notably the HD channels -– not being able to control the volume from my Humax remote, (something my old Sony TV would allow).
It's a great TV picture and the product design is exactly what I wanted.
But ANDROID TV is a disaster...
And another thing.. Why the F*** cant I add SKYPE as an Android App and buy a camera for the TV so I can use whole TV for SKYPE??!!
Is it really that hard?
Sideload Skype onto it, i had to with SKYGO
sorry for late reply... was in London all weekend
interesting read i read there isnt a dual tuner so cant have youview with satellite? one deletes the other? that is odd
what have youview said on this issue? nothing i bet!
Yep, looks even better after the latest update...
and yeah keyboard / mouse to navigate
you cant update app, but i just extract it and update manually
