Android 5.0.2
Build SVPDTV15_EU_user 5.0.2 LGY75.S147 2.333 release-keys
Sorry don't use Netflix ;(
It's still summer for us in the UK, autumn starts Wednesday September 23rd, until Monday December 21st,
@angelacr wrote:The Dutch Sony site has System updates with serial 2333......
It's a special update to solve the reboot issue, when using a CI+ module....
Has anyone got a 43X8305C thats running without any problems of sluggishness? Mine is going to go back to JL this week - it has a maufacturing date of 04/2015. Was Hoping Sony would have released the Youview and other updates before my 90 days were up, but this doesn't look likely now. If it does get sorted I'll buy back cheaper or wait until the 2016 models come out, Can't see anything else I would like from any other manufacturer as 43 inch fits my room beautifully.
A little off topic I know, but does anybody else use the Archos media app? I purchased it the other night as a replacement for the standard video app on the Bravia because of network issues and not finding devices. Archos worked awesome, plus the added bonus of film info added to the files. But, the last couple days, I have not been able to use the SMB feature to find my NAS and Xperia Z3 to add more indexed folders to the TV app. Oh, and PC. However, thr app on my Z3 has worked without fail since the purchase.
My only remedy for getting the TV app to function again is to uninstall it, reboot the TV and install it again, then index the folders.
Force close, clear cache or just simply uninstall / reinstall without a reboot of the TV doesn't work.
I have to uninstall, reboot, install! It finds all the devices once more, and I can access the folders with films in again.
Also, does Archos only play video, can it do music or pictures?
Not Archos, but I use MXPlayer Pro, which has been a favourite since Asus TF101 days, because it seems to get the best from sluggish hardware.
I use the free MX on my phone, does the pro version have network access to drives on it?
I presume so, I'd have to check though, as the only network fileserver I have for video is my Humax FreeSat HDR with Mediatomb on it, I've never tried it.
EDIT: It does work but MX Player doesn't have a built-in DLNA client, so I had to use BubbleUPnP, which is a bit clunky on the TV.
Skifta is probably better, but you have to sideload it now, as it is no longer in the Play store.
EDIT2: Aha, a reboot of the TV seemed to sort the display problems out on BubbleUPnP, it's now working very well with MX Player Pro set as default renderer, over Ethernet though.
Try it with the free version of MX Player first (Y)
I have bought the Archos too, it saved me, I am using it daily to watch movies, Netflix doesn't have plans to visit my part of Earth any year soon. When I see that it cannot explore SMB servers at home, I have 5 in total - 2 Xperia phones, laptop and two PC's, I just unplug the TV for 10 sec, and then Archos finds and plays as new. I suspect that its some kind of out of memory issue with Android. So just fresh start helps. I don not know why Sony do not allow us to insatll some memory manager on the TV, just to clear some free memory instead to unplug action. I think it would be safer for the TV. So I have the TV for 2 months now. I need to unplug it from wall nearly 2 times a day.
