Fix it or leave it?
profile.country.SI.title
Scehhh
New
Fix it or leave it?
I bought a used 200 - 600 g lens. Works perfectly and picture quality is great. The only problem I have is a Chiped filter thread.
should I be worried and get it fixed or leave it? I am not planing to use any filters with it as I read it can mess up the auto focusing.
If it rains i plan to use a rain cover.
I plan to go on a safari one day, i know it can get dusty.
There is no visible dust inside the lens so I guess it is still weather sealed? Am I stressing to much?
i got it for a really good price used and failed to notice it upon inspection but does not look like it was droped and is otherwise in perfect condition
0 REPLIES 0
