After updating to Android 13 (firmware 61.2.A.0.381), my phone can no longer pair to my Honor Band 6.
I contacted Sony support and I received a canned email saying I had to use the Xperia Companion app to do a restoration. Although sceptical that this would work, I did so to no avail (the restore process factory resetted the phone)
I also contacted Huawei, has anyone troubleshooted anything similar with Android 13 and Huawei accessories?
The issue was resolved by installing the latest firmware update for Honor Band 6.
I paired it to another phone running Android 12, I installed the latest firmware update via the Huawei Health app and then paired it to my Android 13 phone.
Resolved for me on Jan 28, 2023
hello @thdervenis
was there any error that showed up when you try to connect the device? have you tried to reset the band instead?
Hi,
I have the same problem with Xperia 10 III. Any news on this?
Thanks in advance
Have you tested any other BT devices with the phones? Or does it only affect that specific smartwatch? Or only Huawei devices? Would be interesting to check that.
Solved in this way (mixing info from other posts on the web):
Hope you can solve the issue in the same way.
