Xperia 5 Camera Crashing
Raggeh
Hi all,
I just got my brand new Xperia 5 and right out the box it crashes when I use the camera. 50% of the time if I take a photo, the phone freezes for a few seconds and restarts. This even happened in safe mode. I've removed the SDCard I had but the problem still persists. There has been an update for Android but it's still a problem.  I'm going for a factory reset but I'm not massively confident. Has anyone else seen this?
Cheers,
R.
5 REPLIES 5
Jonyny
this exact issue happened to me today.
but i noticed there is similar issue reported with xperia 1
profile.country.NL.title
Strampke
Try a forced reboot.
Push power and Vol-up simultaneously until the device vibrates.
See how it goes after the reboot.
I have Xperia 1 which hasn't shown any problems so far. Not with camera, not with anything else.
Wrong: the fingerprint scanner isn't functioning as it should. It's a random choice of it accepts the fingerprint.
Yekollu
Contributor
No amount of Reboot is going to fix this, appears to be a HW issue.... Get in touch with Sony or your retailer, you should get a replacement or a refund
Bee_w
I'm having the same issue with my phone, pretty much making the camera unusable! Really disappointed with sony as I've always been a huge fan. Will this be getting fixed?
Strampke
When your camera app keeps crashing you should consider a software repair.
Before you do so make backups.
Messenger apps have to be backed up from within the app itself.
There is lots of information
  • on this forum Information->FAQ
  • In the Support app on your phone
  • On Youtube
BTW: Before acting charge battery > 80%
