Hello
Dears after greeting
I would like to check if my Xperia 10 plus is original or copy because i checked IMEI code in website the result is PM-1191-BV by Sony
This result make me worry is my phone original or copy
Hi @MD202, welcome to our forum!
You can send me a private message if you click on the link below and then you tap on "Send a message" in the top right corner.
/t5/user/viewprofilepage/user-id/885297
Include the IMEI number in the private message (Open up the phone app and type in *#06#).
Thank you.
While checking the IMEI number in a website the result shows PM-1191-BV by Sony. Is it OK. Pl. let me know.
Hi @Ponnambalamsb, if you can send me a private message with your IMEI number, that would be the best!
Thank you.
