Xperia IV,two headphones same source?
profile.country.SE.title
dsdsds
Is it possible to have two wf-xm4 playing the same source simultaneously connected to xperia iv?
Followed the "share audio guide" but i dont have the same options as presented.
Best regards,ds.
8 REPLIES 8
Piscie
Hey @dsdsds
Have you followed the steps in the manual: https://helpguide.sony.net/mobile/xperia-1m4/v1/en/contents/TP1000786919.html?search=share%20audio?
If so, what settings are missing in your phone? And what is your Android version?
dsdsds
I have android 13,latest updates on all three units involved(phone,wfxm4,wfxm4).
Both pair of headphones are connected and active.
When i follow the instructions i get to that point where im supposed to activate the "audio sharing device option" in the pair of headphones id like to share wich is not present.
Its in row/point 5 in the instructions.
Thank you for assisting me,D.
dsdsds
The option wich isnt present  is called "Add audio sharing device"
My bad in naming it wrong in previous post.
EMS_MO72
Hey @dsdsds
Can you send a screenshot or a picture showing the options in the menu that you have?
dsdsds
Audio share is activated.
I have no options to activate share audio in neither pair of wf-1000xm4 nor my wh-1000xm4,even tried my Earin A3.
I live in sweden but switched language on the phone for the screenshots sake.
Could it be a region restriction ?
Piscie
Hello @dsdsds, it could be yes. As per the manual, in some regions and countries, LE Audio will be made available through another software update after the Android 13 update.
dsdsds
I suppose its a region thing then,thank you for trying to help me out.
Best regards D.
Piscie
@dsdsds, you're always welcome! Keep an eye on these options after the next software update. Hopefully it will be fixed.
