Home button!!!
Hafar
Visiteur
Home button!!!
Pls how to change home button function
When press home button will open googel, how if I want change to open another app?
2 RÉPONSES 2
Xperia1user
Visiteur
setting-->default apps-->assist&voice input
you can only change to other assist app or turn it off
hope it can add a double click home button get split screen features
/t5/Xperia-1/Please-add-double-click-home-screen-button-get-split-screen/m-p/1381356#M1911
profile.country.US.title
Qatrium
@Hafarilqbor
The home button will show Google Assistant only when you long-press on it. It has other functions you can read about here:
https://support.sonymobile.com/global-en/xperia1/userguide/navigating-applications/
If you want to change the behaviour of the home button totally, you might need to install a 3rd party launcher from Google Play store (like Nova Launcher, for example).
