A1 Camera set memory issue
GordonT
Using v2.00 firmware.
If l set the resolution to 21MB (APS-C cropped) and save it to Camera set.memory if changes to 50MB (FULL FRAME) on recall.
And if l set the camera to 21MB crop and switch the camera off and on it goes to 50MB full, a bit frustrating.
I don't think it did this with the old firmware.
6 REPLIES 6
TheMaze
Hey @GordonT
You can try updating to v. 2.01 and check if it fixes this issue. It has been just released, a few days ago.
https://www.sony.co.uk/electronics/support/e-mount-body-ilce-1-series/ilce-1
GordonT
Using v2.01, no change
GordonT
Do you have an A1 to try it on ?
GordonT
Here's the sequence, showing saving at 21MB, recalling at 50MB...
IMG_20240505_192226.jpgIMG_20240505_192946.jpgIMG_20240505_192456.jpgIMG_20240505_192531.jpgIMG_20240505_192608.jpg
TheMaze
Hey @GordonT
Are you using a compatible memory card from here?
https://support.d-imaging.sony.co.jp/www/cscs/accessories/?mdl=ILCE-1&area=gwt&lang=en_GB
GordonT
Yes
CEA-G80T
